configure vm-tracking vpp vlan-tag
configure vm-tracking vpp vpp_name vlan-tag tag {vr vr_name}
Description
This command configures the VLAN tag and VR name for VPP. If the detected VM MAC uses this VPP, then the port in which the VM MAC is detected will be placed on this VR/VLAN.
Syntax Description
vpp_name Specifies a name for the LVPP.
tag Specifies a name for the VLAN tag.
vr_name Specifies a name for the Virtual Router.
Default
N/A.
Usage Guidelines
Use this command to configure the VLAN tag and VR name for VPP. If the detected VM MAC uses this VPP, then the port in which the VM MAC is detected will be placed on this VR/VLAN.
Example output not yet available and will be provided in a future release.
This command was first available in ExtremeXOS 15.3.
Platform Availability
